Removing the turbo ??
take the cover (if you have one fitted) then undo the three nuts holding the exhaust on
then the slighty tricky bit is the four nuts that hold on the turbo due to space limitations
but if you can do all the above should come straight off
might be wore while spraying all the nuts with a penertrating release oil of some kind first and letting it soak in
The turbo will come off by just removing the four nuts, but a variety off spanners are required. But be warned even with these nuts undone, it may not move. I had to whack the living daylights out of mine to break the initial seal with a soft hammer, no amount of wd40 did it. Once that seal has broken its oK, I changed my turbo 4 times in two weeks, so it can be done with just the four nuts.
get a ring spanner and cut part of the ring out to make it three quarters of a ring,you will also need to bend a spanner or 2 as well,quite time consuming but a lot better than removing head or exhaust manifold
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
