17" alloys
Old Jun 18, 2007 | 09:47 PM
dakar's Avatar
dakar
Default 17" alloys
Just put some new alloys on my saph and if i brake heavy on the drivers side the tyre hits the wing.Its on standard suspension is it just my suspension is shagged or do i need to look at a problem elsewhere
cheers
Old Jun 18, 2007 | 09:58 PM
Souleyman's Avatar
Souleyman
Seems too small ET, or too high or too large tyres, or too soft suspension. The last cause is the main.
I met this problem on my scorpios with 16" and 18" alloys, but after install H&R springs and KONI-sport the problem went away.
Old Jun 18, 2007 | 11:22 PM
xr_craig's Avatar
xr_craig
Probably suspension worn mate.
Providing the wheels are the correct offset and the tyre size is right then there should be no reason for them to catch
Old Jun 19, 2007 | 07:05 AM
Wrong size/offset wheel.
It may of course be being made worse by soggy suspension, but not caused by it, as there should be enough clearance there what ever the suspension is doing, clearly there isn't.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
