Will a Group A rear beam work with std rear suspension legs?
The mounting points are the same - aren't the pick up points also? I thought it would work with all the multiple points for the rear legs . . .
Whats different?
Whats different?
If you mean the rear beam that is made by either Ahmed or Zoo, then yes they will work with standard rear suspension legs. All the rear beam does is change the angle that the trailing arm proscribes - instead of being an arc - it is straight up and down. So doesn't matter what dampers are used.
Have you felt the weight of the square rear beam mate? It weighs a fooooookin tonne as it was designed for gravel rallys. Even the mag rear arms are about twice the weight of standard, or our rear arms.
Another advantage of our beam over standard (apart from what Mike has stated) is that you have fully adjustable camber and toe.
Sean..
Sean..
I have heard good things about the Zoo stuff - but the square rear beam is going on a gravel rally setup really (and some road use too in the summer months) - I just wanted to know if it'll work.
Right now I have a tarmac bilstein setup on right now and I have to have a ton of camber on the rear to get the car to sit low enough. I bought a square beam this spring and am planning to fit it soon, but I saw one on ebay and the auction says it will not work with standard legs - just wanted if it'll work since I was going to change the diffs and chain to 3.9 ratio.
as i understand it, it won't run with std trailing arms (is that what you mean by legs?) and needs the mag ones and a tie rod. what dampers they need, i don't know, but surely must require coilovers as there is nowhere on the mag arms for the std type of springs?
Trying to stay a bit in budget - that's why I was hoping to use the standard trailing arms with the beam, and yes I do have the 42mm coilovers all around.
I would have to change too much stuff for proper mag arms - go to Grp A wheels, brakes, hubs, etc etc. Still waiting on that Group A coolant tank I bought from you - stupid royal parcel!
By the way I have a cosworth fan in Ohio that posted pictures of my car . . . here's the link
http://www.cardomain.com/id/oneloudmerkur
155lee
Sep 14, 2015 07:37 PM
155lee
Aug 14, 2015 11:21 AM
Graceland
Jul 31, 2015 10:34 AM
I converted to coilovers when mine went on.
