Original head gasket bhps
Old Jun 17, 2007 | 10:34 PM
Souleyman's Avatar
Souleyman
Default Original head gasket bhps
For what bhp.s is enough to use original cosworth head gasket without any problems?
Old Jun 18, 2007 | 06:35 AM
On the standard head hasket, SOUTHAMTON UNIVERSITY were having to do head gaskets on STANDARD BHP engines when the did the NVH testing for FORD/COSWORTH.
Standard one is not worth having really even with standard power.
A group a one YB 0611 will cope most say up to around the 400bhp mark, and is FIBROUS so a very good one, as it will cope with any slight imperfections in flatness of head/block much better than meatal ones.
Old Jun 18, 2007 | 02:05 PM
Souleyman's Avatar
Souleyman
In my full gasket set from motorcraft was victor reinz head gasket. Can I use it with no fear for power around 300-350?
Old Jun 18, 2007 | 02:53 PM
TurboShed's Avatar
TurboShed
Cossiemodo
At the end of the day a gasket failure isn't a great event, if you have it already I'd just use it. It's not like 300-350 bhp is massive in the scheme of all things Cossie.
Old Jun 18, 2007 | 07:31 PM
Victor Reinz make the oe ford one and the group a.
A std one will not last as long as a group a, if you look very carefully on the end top side you will see it's number faintly printed.
Victor reinz also make a SINGLE PIECE METAL GASKET!!
Old Jun 18, 2007 | 08:01 PM
Souleyman's Avatar
Souleyman
The number is: YB 1261
it means that I can use it with the 300-350 bhp, mates?
Old Jun 18, 2007 | 09:59 PM
costina's Avatar
costina
Live long and prosper!!
I've seen many cossies running 300+ bhp with std gaskets
imo its a lot of hype gasket failer is mainly due to the early 2wd heads not being that good around the water jacket area...and people drivin cars when they know they have a problem eg leaks overheating etc
And poor fitment surfaces must be spotless and a good quality torque wrench should be used
I personally cannot see any difference between a std and a grp a only the numbers
Old Jun 19, 2007 | 07:19 AM
The number is a std part number.
There are of course different opinions on this subject, only you can decide what you are happy with.
They are made differently, if I could find the letter from V/R I would post it but can't, probably not got anymore.
Southampton UNI had perfect heads blocks etc all with NO MILEAGE, and only 10 minutes on them and they STILL failed.
I do appreciate what COSTINA says and to a large extent it is right, but certainly not all failures are due to this.
Old Jun 19, 2007 | 08:43 AM
bud-weis's Avatar
bud-weis
Football Cwazy
the 1261 is a standard small turbo escort cosworth gasket isn't it? in which case it's just as good ( probably better ) then a Grp A 0611
Old Jun 19, 2007 | 09:13 AM
Souleyman's Avatar
Souleyman
Thanx mates, I ready to install this std and if it failed, that will be the karma of my gybrid scorpio-cosworth!
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
cossiedean84
37
Sep 2, 2015 10:19 PM
mint_s2
Sep 2, 2015 08:58 AM
IAN RS2k
Aug 18, 2015 07:51 PM
