OddKidd's MK4 Escort RS 343bhp with STD Engine.
Ask me a question!
(Posted in the RST section but should of started a project page for it
Been working on this car for a while now, thought id start a thread here to read your views.
Wasnt expecting to be able to get such good power figures from a std engine. I will remove this engine soon to make way for a bigger stronger engine. Untill then i thought id have some fun.
The spec is:-
Cosworth Management running P8 with ALS, Coilpack, WI etc.
Green 803 Injectors
3 Bar map sensor
Pectel engine Loom
T34 with 360trust and .48 housing, upgraded studs and bolts ect.
-34 actuator
)Been working on this car for a while now, thought id start a thread here to read your views.
The spec is:-
Green 803 Injectors
3 Bar map sensor
Pectel engine Loom
-34 actuator
The spec is:-
Green 803 Injectors
3 Bar map sensor
Pectel engine Loom
-34 actuator
The spec is:-
Green 803 Injectors
3 Bar map sensor
Pectel engine Loom
-34 actuator
Ask me a question!
there are loads of pics already up on the net.
http://oddkiddcreations.co.uk/forum/viewforum.php?f=11
Regards
