fiesta turbo relays
need some help m8 having troubkles with his fiesta turba not sparking
he had some pointers he was told to cheack fuses which he has but also been told to have a look at the relays
this the problem where are the relays on a fiesta turbo???
go for the green on, burnt pins are common, clean the pins and refit, or if that dont work fit another.
norm thing if its not sparking is the CPS, take the plug off and spray with wd40 and put it back and try
get details of what parts his tried and what his changed.
if hes not getting spark its due to CPS or the plug, although CPS it self dont norm go wrong,
wierd i know, but mabye the cps wire is get caught under the gearbox mount and crushed
the edis is naff, wiring to the coil pack is bad.
ive not come across a coil pack thats gone down though
or as said above, fault within the fuse box, norm with the green relay mate
tell him to pm all the details if he dont wanna post them up
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
