2wd saff temp guage not working
Old Jun 14, 2007 | 11:39 AM
mikelomax's Avatar
mikelomax
MOUSE
Default 2wd saff temp guage not working
my temp gauge has stopped working on my 2wd saff, what should i test or look at to find the problem.
Old Jun 14, 2007 | 11:56 AM
Look to see if the end of the connector has snapped of by the turbo, front of head above alternator, this often happens.
You can test the guage by switching ignition on and earthing out the wire when it should read FULL RANGE ie super dooper hot.
Old Jun 14, 2007 | 12:24 PM
mikelomax's Avatar
mikelomax
MOUSE
when i turn the ignition on the needle moves a tiny bit (nowhere near the scale) but i have tried earthing the wire which yes the end has snapped off but still nothing.
many thanks
mike
Old Jun 14, 2007 | 06:21 PM
This wire has most likely got a break in it, take out clocks, and do a continuity test between engine end of this wire and the end at the clocks.
mk22door
49
Mar 26, 2022 07:15 AM
Kop2381
Aug 23, 2015 01:17 AM
COSWORLD
Aug 14, 2015 07:40 AM
