For those who have 19" superleggeras
Old Jun 14, 2007 | 07:17 AM
MATCOS's Avatar
MATCOS
Default For those who have 19" superleggeras
I am considering getting a second set of wheels for my car and as I have the longer wheel studs for the Leggs was wondering if I would run across any problems when fitting another set of wheels due to the stud length, I am looking at old style MO's at the moment, does anyone have any experience with both of these sets of wheels and swapping them over please.
many thanks
Old Jun 14, 2007 | 08:35 AM
cossymad's Avatar
cossymad
4 options Matt.
1. Use open ended wheel nuts when using the Mo's with no spacers
2. Use an Et40 set of Mo's
3. Change the spacers for ones that retain the original studs, and merely unbolt.
4. Knock the long studs out everytime you swap your rims over
Old Jun 14, 2007 | 08:47 AM
MATCOS's Avatar
MATCOS
Thanks Chris
The wheels and bolts are from you originally, and the nuts for the MO's are Group A sleeved ones, I think they are open ended, but what I don't want is stupid little stubby wheel bolts sticking right through the wheel nut and ruining the atmos!!!
Old Jun 14, 2007 | 01:14 PM
cossymad's Avatar
cossymad
your choice
Old Jun 14, 2007 | 07:50 PM
Dunccoss's Avatar
Dunccoss
mat i could just bring one to the show this weekend and you can try it and see
Old Jun 14, 2007 | 08:22 PM
Rippers's Avatar
Rippers
Monte Geek
I quite like the little bit of stud showing
Old Jun 14, 2007 | 08:30 PM
Dunccoss's Avatar
Dunccoss
mat as you can see from this pic the group A sleved wheel nuts are long
Old Jun 16, 2007 | 09:25 AM
MATCOS's Avatar
MATCOS
Thanks Dunc as per PM
Paul I see what you mean it doesn't look as bad as I thought it would
I will see tomorrow when I trial fit one
Si B
Alloy wheels and ICE for sale
Jun 21, 2012 04:33 PM
baba
Oct 27, 2010 06:47 PM
cawsey18
Aug 25, 2010 09:31 PM
