code reader ford escort?? Ford tech???
Old Jun 13, 2007 | 06:47 PM
D7AKE's Avatar
D7AKE
Default code reader ford escort?? Ford tech???
Iam trying to buy a code reader for my car escort 98 how do I tell if its obd 11 complient?
anyone know?
Old Jun 13, 2007 | 06:54 PM
iansoutham's Avatar
iansoutham
OCD Victim
Quite simple, all major manufacturers made their vehicles OBDII compliant from 1996 onwards when the statutory requirement was introduced.
Your 1998 Escort should have the diagnostic plug down in one of the kickpanels (normally r/h side).
If you want a decent reader, do an ebay search for an Autel OBDII reader (cost about Ł20 delivered).
Old Jun 13, 2007 | 08:01 PM
D7AKE's Avatar
D7AKE
amazing thanx for that
Si
Old Jun 13, 2007 | 08:02 PM
richm's Avatar
richm
Si,
diagnostic connector (16 pin oblong "D" shape) is in the passenger side kick panel, behind a cover plate that prises out to expose the connector.
Yes should be obd2 compliant in the accepted sense.
If you get a generic OBD2 (or "EOBD" ) compliant reader, don't expect it to be too comprehensive, the general obd2 spec only requires the vehicle manufacturers to provide standardised emmissions related fault codes, the rest (referred to as "Manufacturer specific") need not neccessarily be accessible to a generic reader, so you may be dissapointed by what you have access to.
Old Jun 13, 2007 | 08:06 PM
D7AKE's Avatar
D7AKE
Rich my Escort Si 1.8 has an irratic idle I wanted sumit to plug in that might point me in the right direction
Si
Old Jun 13, 2007 | 08:30 PM
iansoutham's Avatar
iansoutham
OCD Victim
Si
Depends if the sensor/item in question is out of specification. If it is not, i.e. air leak, then no reader will be of use.
As pointed out above, these readers are generic, although some are better than others.
I use one in work (my own) that we use to diagnose faults and to extinguish engine management lights. Saves us a fortune @ Ł35+ vat a time for someone to come round and do it for us otherwise.
Also, 3 of the lads @ the dealer where I work have these ones I recommended as well as they are just as accurate @ what they do as the Vauxhall ones and normally access the data quicker as well for some reason.
Obviously, they are restricted in that they cannot work on airbags, etc... or programme keys like the dedicated ones can, but, will work for what you want.
Old Jun 13, 2007 | 08:37 PM
richm's Avatar
richm
Si,
Idle speed control valves on them are notorious for getting full of crap and sticky, closely followed by throttle position sensor, and possibly lambda (exhaust gas) sensor - not forgetting the associated wiring... All will have a direct effect on the idle behaviour, and as stated above, unless they are operating well outside spec, or have obvious fault, then it's unlikely a fault will be logged anyway. Is the Check Engine light on in the dash?
Old Jun 13, 2007 | 09:10 PM
D7AKE's Avatar
D7AKE
Originally Posted by richm
Si,
nope there is no engine check light on and I was told that mine did not have an idle speed control valve??? but Iam not sure
The engine hunts and it is more obvious from the exhaust on idle is phuts but its quite random....
car drives but seems under powered...
thanks for you help...
Old Jun 13, 2007 | 09:11 PM
D7AKE's Avatar
D7AKE
Si
Ian can you point me in the right direction to one of these readers on Ebay as I cant find the one you quoted above?
Old Jun 13, 2007 | 09:28 PM
D7AKE's Avatar
D7AKE
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=014
wot abot this?
Old Jun 13, 2007 | 10:07 PM
iansoutham's Avatar
iansoutham
OCD Victim
Si,
Look from under the car to the bottom of the inlet manifold. There will be a little silver / chrome valve assembly held on with 2 x 10mm bolts and a 2-wire plug going to it. That is the idle-valve.
It will be a bitch to change also normally.
May not be the idle valve. Was only a hypothetical cause (although it is common as muck and most dealers keep it in stock @ approx. Ł66)
Old Jun 13, 2007 | 10:09 PM
iansoutham's Avatar
iansoutham
OCD Victim
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=330133034589&ssPa geName=STRK:MEWA:IT&ih=014
wot abot this?
As good as any. Reasonable price too.
Old Jun 14, 2007 | 08:17 AM
http://www.dntn.co.uk
All the codes you want.
Old Jun 14, 2007 | 11:28 AM
D7AKE's Avatar
D7AKE
Thankyou
Old Jun 14, 2007 | 09:45 PM
D7AKE's Avatar
D7AKE
I swapped the coil today but that made no difference, I'm going to change the iscv next as I have found mine and your right looks a bitch to get to
would this effect normal driving conditions? as well as idle?
Si
Old Jun 25, 2007 | 06:19 PM
D7AKE's Avatar
D7AKE
Update..... its getting better changed oil today and checked compression low on no3 put some valve cleaner in and its got better not perfect yet but better.............
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
