blue motorsport leads...
saff is working!!!...atm
anybody had problems with them..???....i had a missfire on my car about 6 weeks ago...so i got dissy cap+arm and put another set of them leads on.....it cured it!!!!..........well its started again...it happens at around 6500rpm in 5th...doesn't do it in 4th or 3rd....the plugs are fine,....just wanted peoples thoughts cos i've been told that these leads arn't that good....cheers Pete
not expert but I've had a few sets on cars that have come in and I've noticed.
the metal clip in the rubber boot that pushes into the cap snaps you can't see it but when the leads are pushed in it will make contact then vibrations causes to seperate and misfire.
the fittings on a 2wd are 90degree but 4x4 are straight which make it less prone.
HTH
HTH
HTH
HTH
With the 2wd having a right angled distrubutor cap and straight start to the leads..
And the 4x4 having a straight distrubutor pins and 90 degree angled leads...
Or have i got it wrong
I had new 909 leads on mine when I got it, but it misbehaved, had a permanent stutter, rolling road showed up bad leads, 3 out of 4 were dodgy.
I put on new MAGNECOR and solved the problem, and mine were STRAIGHT, with ANGLED CAP.
HTH
HTH
Originally Posted by gym-rst
I have a set of ford ones doing nowt marra if you want to try em out
Originally Posted by cossie350
Originally Posted by pete mcrash
plugs have only done about 5k...NGK iridiums........but like u say...shit happens....
Im lucky if i get half that before they fook up.Thread
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
job done
