lambda sensors, Zirconia and titanium, anyone explain
Old Jun 12, 2007 | 06:53 PM
jayRS's Avatar
jayRS
Default lambda sensors, Zirconia and titanium, anyone explain
whats the difference between the 2? mainly this is based on the fact i need to buy one for the wifes 2 litre ford galaxy and looked on ebay an found theres 2 different sorts, whats the difference and does it matter which is used on the wifes galaxy?
Old Jun 12, 2007 | 07:31 PM
jayRS's Avatar
jayRS
some one must know?
Old Jun 12, 2007 | 07:36 PM
SteveB's Avatar
SteveB
All I can remember from a course I did was that if you fit the wrong 1 it'll give a dodgy signal... I really should have paid more attention in class
Old Jun 12, 2007 | 07:38 PM
jayRS's Avatar
jayRS
worse bit is i dont know which one the wifes car uses
Old Jun 12, 2007 | 07:45 PM
SteveB's Avatar
SteveB
Imo... ring a parts place or even better Ford and get the info out of them
Old Jun 12, 2007 | 07:57 PM
If it has any red wire it will be a TITANIA one, as only a few jap cars have no red on TITANIA.
TITANIA are either 3 or 4 wire, and are 0-1volt OR 0-5volt, four wire will have a YELLOW wire.
Failing that it will be a ZIRCONIA, 1,2,3, or 4 wire.
Single wire(black) is just signal and earths through the exhaust.
2 wire is white earth, black signal.
3 wire is black signal, two whites are heater, which way round does not matter, one live, one earth
four wire are black signal, grey earth, 2xwhite heater.
ALL are 18mm x 1.5mm thread, as a general rule TITANIA tend to be longer slimmer bodies.
Old Jun 12, 2007 | 08:06 PM
jayRS's Avatar
jayRS
they wouldnt know mate, they would sell me one (£101 plus vat ) but thats all
hmm that makes sense, i do have a couple of old ford ones, 2 white, 1 black 1 white, from what i can see in the galaxy its the same, but ive not been down on my back having a look.
cheers for the replys guys, ill go seeif its right and then buy the cheapest brand new one i can find on ebay..
fucking MOT
Old Jun 12, 2007 | 08:10 PM
ECU Monitor Enthusiast
Here is some good generalised information.....
http://en.wikipedia.org/wiki/Lambda_sensor
Didnt know Volvo invented them
Old Jun 12, 2007 | 09:52 PM
jayRS's Avatar
jayRS
cheers dude, thats a interesting read, shows what little i thought i knew about them
well after nearly cutting my arm up on the fan housing and the exhaust manifold heatsheld i just about reached the plug on the galaxy to see it has 3 white wires, 1 black and one grey.
take it i can use the cheapy sensors like this then?
http://cgi.ebay.co.uk/Lambda-O2-Sens...QQcmdZViewItem
http://cgi.ebay.co.uk/NEW-Oxygen-Lam...QQcmdZViewItem
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
