restoration 2wd sapp
Old Jun 11, 2007 | 10:09 PM
capri280's Avatar
capri280
Default restoration 2wd sapp
nearly finished and have the following probs
No power at fuel pump to run the pump(Pump is working i tried direct wiring)
Having direct wired the pump to another fully charged battery and cranked the car over it will not start fuel is passing and returning by the fuel rail
any ideas
Old Jun 11, 2007 | 10:32 PM
tichy.cosworth's Avatar
tichy.cosworth
run a live from battery and use a relay in the Tyre well done it to mine have you check fuel cut out switch in boot
Old Jun 12, 2007 | 01:06 AM
jon@work's Avatar
jon@work
Check the fuel pump relay and fuse (behind the glove box).
If either is at fault, then not only will the fuel pump not work, but you'll perhaps (fault dependant) not have +12V at ECU pin 28, the amal valve, and the idle speed control valve
Old Jun 12, 2007 | 05:55 AM
Get yourself a wiring diagram and follow it!!, if you want one PM me and I'll post/email, or fax you one, if you can get to a COLOUR fax, work one maybe ?
Check also your main relay, this is fed from the ignition switch along with the fuel pump relay, you need to check that you have a direct feed from the battery into each of these relays when ignition is off, so as not to confuse it with switched supply, it's a lot easier with a diagram ?
Old Jun 12, 2007 | 03:00 PM
2001ode's Avatar
2001ode
Default Re: restoration 2wd sapp
any ideas
Hi,
Check if your emergency switch is ON, on spare wheel boot.
Regards
Claude
Old Jun 12, 2007 | 04:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
does your ecu have power? there are 2 relays and fuses behind passenger dash - 1 for ecu, 1 for fuel pump
when you go to key 2, the SEM boost control valve (mounted on the intercooler) should click
forget inertia switch, it's obviously not the problem or it would start when you direct wire the pump
Old Jun 12, 2007 | 05:35 PM
2001ode's Avatar
2001ode
any ideas
Hi,
Regards
Claude
Sorry,
Bad reading of initial problem !!!!
ForeignRS is right !!!!
Claude
89barto89
Oct 4, 2015 06:59 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Pwrs2k
23
Sep 26, 2015 09:45 AM
