Do anyones 19's rub on the wheelarch liner when cornering?
Old Jun 11, 2007 | 08:52 PM
MATCOS's Avatar
MATCOS
Default Do anyones 19's rub on the wheelarch liner when cornering?
My tyres seem to be rubbing on the top of the wheelarch liners under acceleration /hard cornering, I've got the Koni's on hardest setting and they still do it, it's only lowered by 20 mm on Eibachs and I don't remember it doing it before, could the top spring cups be broken?
any suggestions guys
Old Jun 11, 2007 | 08:54 PM
rapidcossie's Avatar
rapidcossie
Default Re: Do anyones 19's rub on the wheelarch liner when cornerin
fit 18's and forget the bling factor
Old Jun 11, 2007 | 08:55 PM
MONSTER's Avatar
MONSTER
Mine never rubber Mat, but then again they never inspired enough confidence to really hammer it round corners
Old Jun 11, 2007 | 08:58 PM
MATCOS's Avatar
MATCOS
Could it be the spring cup thingies at the top Dave
I am seriously considering going back to standard wheels
Did you win at LWV, any more new people entered in Novice?
Old Jun 11, 2007 | 09:21 PM
MONSTER's Avatar
MONSTER
I wouldn't like to guess mate, just strip it down & have a look, give you a chance to do some more cleaning
Won at LWV but then again i was the only entrant
An unexpected bonus was car of the day though
Old Jun 11, 2007 | 09:43 PM
THE RADMAN's Avatar
THE RADMAN
my r/harts used to clear ok, with 225/35/19" the rears used to just catch though when the kids were in the back remove the top nuts in the engine bay,remove top plate and you will be able to see if the cups are broken,save stripping stuff down, you would normally hear the noises though if they were knackered, well done dave,car looked mint,came across to see you but you werent there
Old Jun 12, 2007 | 06:25 AM
MONSTER's Avatar
MONSTER
Thanks Nick, yours looked too mate. there never seems to be enough time at these shows to chat to everyone!
Old Jun 12, 2007 | 07:35 AM
cossymad's Avatar
cossymad
Mine never rubbed at all even 4 up 225/35/19, apart from when the washer bottle bracket retaining nut came undone and pushed the archliner onto the tyre. I reckon it could be the top hat, or the shocks could have blown.
Old Jun 12, 2007 | 10:37 AM
MATCOS's Avatar
MATCOS
The shocks have only done a few thousand miles tops-is this likely
I will check the tops and check to see if the wheelarch liners have dropped somehow-I will be really annoyed if the shocks have gone
Old Jun 12, 2007 | 10:47 AM
cossymad's Avatar
cossymad
Not likely, but possible, as you said it did not rub before !!
Look how low this is...same wheels as yours;
Old Jun 12, 2007 | 11:25 AM
MATCOS's Avatar
MATCOS
Chris mine is nowhere near your lowrider I will have a look this evening and see what I can see, it deffo doesn't sit any lower than it has before, maybe it's something obvious I am not seeing.
cheers
Old Jun 12, 2007 | 11:30 AM
cossymad's Avatar
cossymad
Sounds like the arch liner has come adrift, or the KONI's are f**ked, and underload they are travelling too far. Check for oil leaking round the seals where the piston rods go into the shock body/ strut leg.
Old Jun 12, 2007 | 11:38 AM
MATCOS's Avatar
MATCOS
Thanks mate
is there a way of testing to see if they are knackered
ie could I push them in with my hands if I took them off the car, or would they not be THAT knackered!
Old Jun 12, 2007 | 11:42 AM
cossymad's Avatar
cossymad
Thanks mate
You should be able to compress them and they should return themselves slowly.
Old Jun 12, 2007 | 02:15 PM
rsdene's Avatar
rsdene
i've hammered mine loads with no rubbing, it pretty low too
Old Jun 12, 2007 | 09:07 PM
cos jon's Avatar
cos jon
One of my koni's was fuc*ed after 2k miles.....
Old Jun 13, 2007 | 11:46 AM
MATCOS's Avatar
MATCOS
what were the symptoms and was this after normal road use or track use?
thanks
Old Jun 13, 2007 | 08:47 PM
Stoo's Avatar
Stoo
Vulture alert...
If you're going to punt them, give me a shout please mate!
Can't help with your problem though...sorry
Old Jun 13, 2007 | 09:15 PM
MATCOS's Avatar
MATCOS
Originally Posted by Stoo
Vulture alert...
Iv'e had some very good offers so far mate, still unsure if they are going or not
markk
18
Aug 17, 2015 05:19 AM
Fordmad!
Aug 16, 2015 05:33 PM
