water system pressure, on s2
Old Jun 9, 2007 | 04:35 PM
juffer's Avatar
juffer
Default water system pressure, on s2
finally finished the conversion in my cab, it started a1 but when it warmed up to "warm" the water system became under pressure and got so bad it blew a hole in the header tank on the seem. checked cylinders for loss of compression there fine there is no signs of fumes in the header tank, its got a new thermostat what else could be the problem.
thanks juff
Old Jun 9, 2007 | 06:35 PM
SafeChav's Avatar
SafeChav
well did you bleed the system of air...........
Old Jun 10, 2007 | 09:07 AM
juffer's Avatar
juffer
yeah did that by taking of the small pipe on top of the thermostat housing,
Old Jun 10, 2007 | 11:00 AM
SafeChav's Avatar
SafeChav
you did what
Its a self bleeding system?!
Old Mar 19, 2012 | 04:17 PM
Omitsean's Avatar
Omitsean
How do you bleed the system of air in the water
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
