Build One.....Or Buy One ???
Since buying the M5, (Which is Great)......I'm seriously thinking about building an "Old Skool" track day car/occassional road use car.
Knowing the prices it costs to build a good "Old Skool" car, I'm trying to decide if I should build....or buy one already done.
I recently came across this car advertised for sale..... The guy is asking around the 12k mark....... Bearing in mind it's spec, could I build one for that money.......Or should I buy one already done. (I don't weld, so any welding fabrication I would have to pay for......the rest I could do myself.
Haven't seen this car in the skin yet, so I'm having to assume the shell is reasonable.
Mexico logbook , currently not road legal but doesnt require much work to make it MOT'able..Lights etc etc..Car still runs a full road loom.
Engine:
2.1 HT racing pinto
Cosworth Rods
Accu pistons
50's Webbers
Lightened flywheel
Alloy dry sump
Cosworth starter
Fluid Clutch twin plate
Gearbox is a 4 speed straight cut Quaiffe
Bodyshell:
Full welded rollcage (strut tops)
Perpex windows
large gearbox tunnel
Alloy tank
Alloy drysump tank
Dash Gauges
Fire ex
BLAH BLAH BLAH...
Axle: Gartrac shafts / Atlas axle
Suspension:
Fronts = Gartrac GRP 4 Bilsteins (coilovers) one trackday old
Rears = Bilstein GRP 4 rears (coilovers) one trackday old
5 linked by HT Racing (with watts linkage)
Brakes:
AP 4 Pot 315's front
Wheels: 16" Revs split rims with Slicks 10's and 9's
Engine:
2.1 HT racing pinto
Cosworth Rods
Accu pistons
50's Webbers
Lightened flywheel
Alloy dry sump
Cosworth starter
Bodyshell:
Perpex windows
Alloy tank
Alloy drysump tank
Dash Gauges
Fire ex
BLAH BLAH BLAH...
Suspension:
Brakes:
build one. might be more time an money, least u know its done right. No need to worry incase the dude who built the engine/shell etc cut corners.
Id love to say the man who i got my saf off did everything i wanted, but there were quite a few bodges in there....
Jim, Build one mate there are plenty of mk 2 shells that have been converted cage turets etc,You can then see it for what it really is..
Then as you know engines good spec pop up (cossie) for a good price
IMO it would be cheaper than buying one for 12k
Rollin shell painted etc £4000 that will be mint
engine (cossie) £1200 box £300 Loom £380 (new)
Thats nearly 6k and u know what u got 6k for wheels seats etc
Seen a few shells in back of retro ford for this kiind of dosh
theres a hell of a lot more into just throwing a cosworth engine into a mk.2 shell.
a decent rear axle will cost you £2-£3k.
imo, it will be cheaper buying one already done.
unless you want a really decent shell and spec then it may be better for you to get one to your requirements.
good luck Jim.
have a look in my resto thread just to see a few things that you will need.
good luck Jim.
nico12
Dec 31, 2015 04:42 PM
