FAO JANO ODDKID or anyone re cossie managment bits...
Hi mate/ people
Mate of mine needs the hybird distributer to run cossie management. I beleive its an rs turbo one with a 4x4 cossie phase sensor????
I know steve scott does some nice pre made ones but hes as hard to get hold of as my dead grandad
do you have any of these?? or can you get one?? how much??
thanks
thanks
RSrussell, ta mate. I'll check out his site or get in touch
Moose 130, fook, that sounds cheap
So you can knock them out for 30 quid posted then??
I DONT USE THE DIZZY!!!!
The best setup is without the use of the Dizzy
. This will allow better configuration and adjustment without any cut n shut bits that also have a leaking/breaking problem or even both.......
If you need more info everything you will need to do the conversion can be found here in great detail.
http://members.lycos.co.uk/oddkidd/forum
Hope this helps
Regards
Jano
www.oddkiddcreations.co.uk
. This will allow better configuration and adjustment without any cut n shut bits that also have a leaking/breaking problem or even both.......If you need more info everything you will need to do the conversion can be found here in great detail.
Hope this helps
Regards
Jano
mk3ste
Oct 17, 2021 10:09 AM
deathrider666
Sep 28, 2015 06:12 PM
