Passenger vent no air!!
Hi. With it being such a warm weekend I had the interior blower on in the ECossy. My misses said the passenger vent wasn't working on her side (Yes it was open !). After some investigation I found that once the vent and square casing it's attached to had been removed, there is nothing there for the air to come from.
On closer inspection of redrsmk5's, there is another tube that looks to be part of the dash and head off the the blower somewhere, it has a foam pad on the end of it that the vent / casing sits onto. Well mines missing for some reason. Does anyone know the finis code or if any MK5 Escort one will fit ??
that pipe is an absolute sod to do
theres no way its fell off, have you had the ford immobiliser removed ? as the pipe has to come off for acess,dont think a normal one will fit as the airbox is diff,have you checked the other end to make sure its not just been folded out the way or something?check the heater airbox for an open end just behind/side of centre console
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
