Can't get my left hand front driveshaft back in
Old Jun 4, 2007 | 12:51 AM
captiva's Avatar
captiva
Default Can't get my left hand front driveshaft back in
I took my LHF drive shaft out on my 4x4 Cossie and fitted some Powerflex bushes at the same time, boy what a job, now I have come to put back the drive shaft and cannot compress the spring, inside the inner CV joint, enough to locate the lower ball joint into the spindle carrier. Is it me just being a wimp or has something changed to stop me doing it
Old Jun 4, 2007 | 06:13 AM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to spin the hub as the shaft goes in
the splines don't line up correctly and spinning it will help them slip home
Old Jun 4, 2007 | 10:56 AM
saff cosworth's Avatar
saff cosworth
try fitting the outer cv joint last, put everything together and leave the shock for last, it worked for me...
Old Jun 5, 2007 | 12:42 AM
callumw's Avatar
callumw
If Dojj's suggestion doesn't work then maybe this may help ?
http://forum.fordsierraclub.co.uk/viewtopic.php?t=10501
I used a ratchet strap for tension and a small length of wood to twist the strap and pull the wheels together. Dunno if that's any use
Old Jun 5, 2007 | 03:46 AM
captiva's Avatar
captiva
Default TCA bushes
Thanks guys, now I know it wasn't my ignorance and that other people are having the same problem, I think the ratchet strap seems like the best way as you have a certain amount of control and not likely to slip.Saves skinned knuckles
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
track.focus'd
Aug 12, 2015 05:53 PM
mrmann
Aug 10, 2015 06:51 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
