Is my starter motor about to fail?
Old Jun 3, 2007 | 07:46 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Is my starter motor about to fail?
On startup, the motor kind of clicks a couple of times loudly, whines a little, takes a second or two longer to start than normal.
Old Jun 4, 2007 | 06:15 AM
dojj's Avatar
dojj
Resident Wrestling Legend
check the battery voltage first
it might not be kicking out enough power to give the starter the kick to spin
also check the leads to the starter
Old Jun 4, 2007 | 07:05 AM
TurboShed's Avatar
TurboShed
Cossiemodo
The battery is new, so I'll check the leads.
Old Jun 7, 2007 | 09:13 PM
AndyPen's Avatar
AndyPen
Hi mate - I assume that the motor is tight? Mine somehow came loose a few years back after Ford's replaced it... wasn't dissimilar to the noise you mention. Wasn't too loose either incidentally - had to be up close to see it.
Cheers,
Andy
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
SMILER258
Sep 28, 2015 09:04 AM
marky_g
Sep 12, 2015 04:26 PM
