S1 Turbo - Bent tie bar
Hi,
I just bought myself a S1 turbo front crossmember etc, and it is very good condition apart from the fact that the passenger side tie-bar is slightly bent where it mounts onto the TCA. It's probably about half an inch out.
How could I straighten it? I assume you could do it by heating it up and then bending it, although presumably this a job for an engineering company as I'd never get it hot enough at home...
Does anyone have any ideas as to how I could sort this out?
Mark
Mark
oh surprise surprise
I've bought 2 S1 rollbars and they were all bent aswell, they are like toffee!
MEF sell some very nice rose jointed replacements, £150 a pair though, but you know they are good quality
Thanks for that - it's good to know they can be replaced.
I have got this one pretty straight now by using a blow lamp, vice and a lot of oomph, but I'll probably replace it at some point
So are you saying that it's unsafe to use heat to straighten a bar like this then?
I though that was pretty much standard engineering practice. What would you I have done? Left it bent?
I only used a plumbing blow lamp - it's not as if I got it red hot or anything... Does this still sound dodgy?
Bastard - I though you might be
at least I didn't run it under the tap to cool it down lol
After snapping that rear tie bar once before I'm paranoid about beaking another one. I'll definately be replacing both front and rear tie bars with MEF ones when I've got some spare cash
at least I didn't run it under the tap to cool it down lolAfter snapping that rear tie bar once before I'm paranoid about beaking another one. I'll definately be replacing both front and rear tie bars with MEF ones when I've got some spare cash
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
