setting a pf09 tps..
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
https://passionford.com/forum/viewto...09+tps+setting
Originally Posted by T S M
there is no click on a pfo9 base setting is 70 ohms or there abouts throttle closed.If you are using a l8 that is as accurate as it needs to be as l8 is speed density mapped If you are using p8 pm me and i will look up the voltage settings on monday p8 is speed pressure throttle angle mapped and tps settings are critical.The pfo1 2wd is the one with the click 2wd is 0-5v min to max pfo9 is 5v -0v min to max.I think will confirm monday
Originally Posted by philram
cheers b9kos, i've put it on and it seems to be ok, but i'll check it readings anyway
