Help needed urgently Sapp cosworth 2wd
Old Jun 1, 2007 | 07:40 PM
capri280's Avatar
capri280
Default Help needed urgently Sapp cosworth 2wd
Just finished my restoration and have the following prob
car starts runs for a min and then dies out
Any answers
Old Jun 1, 2007 | 08:30 PM
Is the fuel filter new. It cud b coolent temp sensor,is ur idle set up right.Try n disconnect the idle speed control valve n c if it still runs.
Old Jun 2, 2007 | 06:24 AM
Does it run fine for a minute ?
It sounds like your fuel pump may not be going as they prime so you get a full rail to start with but should not last a minute at all.
Does it run rough when started, more info needed please.
Old Jun 5, 2007 | 08:39 PM
BIL N KEL's Avatar
BIL N KEL
check the fuel pump cut off in the spare wheel well
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
