m.o.t emmisions.
Old Jun 1, 2007 | 07:22 PM
pez's Avatar
pez
Default m.o.t emmisions.
can anyone help please? my 4x4 saff cosworth has failed its test 2day on the exhaust emmisions.the legal limit is 3.5 mines 5.8.ive changed the oil and filter,cleaned the cone filter and put new motorcraft plugs in it.ive even tried the adjustment screw on the ecu,cant get it any lower. thanx
Old Jun 2, 2007 | 06:36 AM
CTS, classic this is.
A new one is about Ł10 from MATT LEWIS 01922 692424.
Put this in check the wiring to it carefully, the reset your CO to 2-2.5% CO, it will, then sail through.
The CTS or COOLANT TEMPERATURE SENSOR is the main corrective factor for the CO(mixture), ie it determines about 90% of it, with little trims from other inputs like air temp sensor.
Old Jun 2, 2007 | 12:07 PM
pez's Avatar
pez
thanks 4 that tabetha,gunna order one 2day.just one more thing though mate if u can help?how do i reset the co?is it something i could do at home or would a garage have to do that? thankyou again 4 ur help,top fella.
Old Jun 2, 2007 | 12:10 PM
pez's Avatar
pez
accidentley clicked on the angry emoticon! sorry tabetha.whoops!
Old Jun 2, 2007 | 07:50 PM
No probs matey, though you didn't love me anymore!!
You need a gastester/metre to read what it actually is, if a freindly MOT place they will be more than happy to do it for you maybe a few quid ?
Just take off the cover over the ecu and there you will see a screw, this is your CO screw, so hook up for the emissions test and then tweak to get reading, you have to give it around 5 seconds after each turn to sort itself out, then just turn until set.
Believe me from your co it will be so much nicer to drive when set correctly, as 5.8 is like having the choke on!!
Let us know how you get on,
Old Jun 2, 2007 | 07:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Do you have to reset the timing after adjusting the co ?
Old Jun 2, 2007 | 08:25 PM
pez's Avatar
pez
thanks 4 that tabetha,i think i know the screw on the ecu that u mentioned,the new sender is on its way then im gunna have to ask the mot place if they will let me try and set it up before another test,ive just given them 40 pound for a mot failure sheet so they better! thanks matey much appreciated,i,ll let u know how i get on in a few days.
Old Jun 2, 2007 | 08:33 PM
dakar's Avatar
dakar
my cossy has just failed MOT on emmisions and mine were only 3.5 i argued that this mixture is what my car is happiest at and the tester said get it below 3 and he would be happy so is it 3 or 3.5%
Old Jun 2, 2007 | 09:14 PM
pez's Avatar
pez
the bloke who mot'd mine on friday told me the limit is 3.5.on the result sheet that they give you it says on mine...max limit.3.5 then actual 5.8
Old Jun 2, 2007 | 10:15 PM
costina's Avatar
costina
Live long and prosper!!
Always thought it was 3.5%
Old Jun 3, 2007 | 06:59 AM
Without a shadow of a doubt it is 3.5%.
No timing does not need resetting as it is not adjustable, CPS does it for you.
Old Jun 3, 2007 | 01:29 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers m8.
Old Jun 6, 2007 | 01:04 PM
pez's Avatar
pez
right.put my new coolant temperature sensor on 2day on went to a local garage for a gas test,using the screw on the ecu i could only bring the co down to around 5 then it starts to climb back up .spoke to neil at carwise,he told me to be careful with the adjustment screw as it can adjust the fuelling as well.gunna have to take it to carwise i think and see if they can sort it out.i really fuckin hate my saff sometimes! thanks 4 ur help though tabetha,much apprecaited
Old Jun 7, 2007 | 07:54 AM
J9BBY's Avatar
J9BBY
I thought the C02 screw adjusted the fuel mixture right across the rev range? Thus perhaps making it lean further up the revs if taken down low on idle?
Correct me if i'm wrong.
Pete.
Old Jun 7, 2007 | 06:47 PM
pez's Avatar
pez
yeah u could be right j9bby,dont know if ive altred my fueling when ive tried to bring my c0 down? gunna have to take it to a specialist and get it checked out.
Pwrs2k
23
Sep 26, 2015 09:45 AM
gsikevin
Aug 5, 2007 12:34 PM
AndyGranger
Jan 13, 2007 09:47 AM
B16ROB
Dec 11, 2006 11:36 PM
WRCjames
Ford Classics & Vintage
Oct 30, 2006 04:26 PM
