Help me someone
Old May 30, 2007 | 05:59 PM
Prabz's Avatar
Prabz
Default Help me someone
Could someone please help me i have Escort LX. Been modified a little bit. Problem is when me driving and i stop the revs go low and it cuts out and then i gotta start it up again. I have changed the Spark plugs and Spark leads and i can't figure out what the problem is. I am not good with cars but if someone can tell me what the problem is i can get it sorted. If someone know the problem please message me or reply thanks.
Old May 30, 2007 | 06:01 PM
RS 5tu's Avatar
RS 5tu
when it starts is it runnin like a bag of s**t
or fine?
Old May 30, 2007 | 06:03 PM
Prabz's Avatar
Prabz
When i start it up it runs fine, but some times when you leave it the revs go under one then it sparks back up it self, or sometimes it just cuts out i don't understand.
Old May 30, 2007 | 06:05 PM
RS 5tu's Avatar
RS 5tu
try gapping ur spark plugs ur self its worth a try just seems strange that when u change them thats when things went wrong..
Old May 30, 2007 | 06:08 PM
Prabz's Avatar
Prabz
what do you mean gapping the spark plugs. No it happened before thats why i changed the spark plugs and spark leads. and now i think its the idle vavle not sure though.
Old May 30, 2007 | 06:12 PM
RS 5tu's Avatar
RS 5tu
ahhhhh :P
could well be ur idle valve
Old May 30, 2007 | 06:14 PM
Prabz's Avatar
Prabz
Ok so i am going to change my idle valve tmoz and ifs not that i will post again but if there anyone else out there that knows that its not idle valve please do let me know thnks
Try cleaning the idle speed valve with carb cleaner.
Old May 30, 2007 | 09:37 PM
Prabz's Avatar
Prabz
i have just done that its still the same, what else could it be if its not the idle valve. Just out of curiosity where can i get a engine re-built from ?
Old May 30, 2007 | 10:19 PM
dazoriginal's Avatar
dazoriginal
prodigal son
had an escort gti similar problem defo idle speed control valve
Old May 30, 2007 | 10:23 PM
dazoriginal
prodigal son
try replacing it rather than cleaning it as i did this also to no avail
Old May 30, 2007 | 10:26 PM
Prabz's Avatar
Prabz
So if i change the idle valve it will not cut out anymore ???.
Old May 30, 2007 | 10:29 PM
dazoriginal
prodigal son
it may cure it then again maybe not but atleast your eliminating things
really sounds like this though
Old May 30, 2007 | 10:31 PM
Prabz's Avatar
Prabz
Thanks Daz, gonna buy a new one tmoz and replace with the old one.
Old May 30, 2007 | 10:38 PM
dazoriginal
prodigal son
keep us updated
Old May 30, 2007 | 10:42 PM
Prabz's Avatar
Prabz
Yep sure will. Will post tmoz to see if its that. Another problem i have is i have a K&N Filter and its not sucking enough air in and on the meter inside the car it goes just under red ?
Old May 31, 2007 | 04:12 AM
Prabz's Avatar
Prabz
BDW guys how much is it for a Escort 1.4 LX engine to get it re-built ??
Old May 31, 2007 | 10:46 PM
morrison's Avatar
morrison
hi m8 dont get the engine rebuilt as it will cost more than the car is worth im sure you can find a good runner out of a nother car and drop it in
Old Jun 1, 2007 | 02:40 AM
Prabz's Avatar
Prabz
Would it work out cheaper, and where is the best place to look ???
Old Jun 1, 2007 | 04:12 PM
MarkN's Avatar
MarkN
If this is a CVH engine it probably means the breather system is blocked up with solidified oil where it enters the bottom of the inlet manifold.
Try cleaning the breather system right out.
Is this car carb, cfi or efi?
Old Jun 1, 2007 | 04:58 PM
djmillsy's Avatar
djmillsy
Fife Radge
buy a zetec its cheaper
Old Jun 3, 2007 | 01:42 PM
Prabz's Avatar
Prabz
How can i tell if the car carb is cfi or efi ?
Old Jun 3, 2007 | 02:57 PM
MarkN's Avatar
MarkN
What year/shape escort is it?
Old Jun 3, 2007 | 10:36 PM
messcortmk6's Avatar
messcortmk6
if it is efi it may be the MAF. mass airflow sensor. if this is not functioning the ECU will not know the amount of air entering the engine there fore cannot give the correct fuel amount, in your case it could be playing up thinking your engine is at high revs past the limiter, where the fuel is then cut off, and as this happens and it is at low revs i could stall the engine.
but please, what escort is it? send a pic if poss.
Old Jun 7, 2007 | 02:04 PM
Prabz's Avatar
Prabz
Its a N reg 1995 escort 5 dr its a LX. i found what it could be. You know the Air Flow meter which if connected to air filter when u dissconnect that engine runs smoolthy cuts out here and there. But when i connect it back in it runs shit, you can hear it, it wants to cut out, but keeps it sparked again then finaly it cuts out lol. i am going to change theair flow meter, and if its not that i dunno what to do so someone please ehlp me :<
Old Jun 7, 2007 | 04:55 PM
djmillsy's Avatar
djmillsy
Fife Radge
sounds like thats your problem mate
Old Jun 7, 2007 | 05:43 PM
Prabz's Avatar
Prabz
Like i said i will change the sir flow meter once i done that i will post back if its that. Thanks
Old Jun 9, 2007 | 10:19 PM
Prabz's Avatar
Prabz
Does anyone know where i can get a new Idle Control Valve, and new Air Flow Meter ???? cant find one any where unless me not been looking hard enough lol
Old Jun 9, 2007 | 11:20 PM
djmillsy's Avatar
djmillsy
Fife Radge
scrappy or ford
Old Jun 10, 2007 | 12:20 AM
Prabz's Avatar
Prabz
i went to scrappys none have it, how much do you think it will be at ford
Old Jun 10, 2007 | 07:06 PM
djmillsy's Avatar
djmillsy
Fife Radge
i would go to ford there not cheap as about for people or ask on here your bound to get one or try another scrappy where are you
