how do you spot a L8 ecu
Old May 30, 2007 | 05:49 PM
boost mad's Avatar
boost mad
Default how do you spot a L8 ecu
in a saph without taking it out, is there a way?
im going to have a look at a saph and dont realy fancy pulling it all apart to get the ecu out to read the numbers, so wanted to no if there was a way of telling with it in situ
cheers
Old May 30, 2007 | 06:05 PM
Shorty's Avatar
Shorty
A L1 or a L6 has mounting lugs on the side (On the hairbrush connector end) and a L8 doesnt.....
Old May 30, 2007 | 06:09 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
same as shorty said.
Steve.
Old May 30, 2007 | 06:45 PM
boost mad's Avatar
boost mad
so it kinda just pisses in the wind then lol
Old May 30, 2007 | 06:53 PM
richm's Avatar
richm
L1 and L6 have mounting ears as part of the case casting because they mount in a slider behind the cover panel in the dash, the ears enable it to be retained with 2 screws.
L8 is mounted in a tray behind the glovebox and clips into the tray, so doesn't need the retaining lugs.
Bear in mind though that it is possible to swap the internals betwen casings to enable them to be mounted either way, so just looking at the outside doesnt neccesarily tell the whole story.
Old May 30, 2007 | 07:06 PM
boost mad's Avatar
boost mad
cheers for the help
this is basicly a possible L8 in a 2wd so assuming its in the normal 2wd position.
we will see
thanx again for everyones help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
DixieTheKid
Sep 14, 2015 09:04 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
