what would cause
Old May 29, 2007 | 06:11 PM
boost mad's Avatar
boost mad
Default what would cause
a sticky wastegate arm on a T34 . even with the actuator off it can be stiff. spray abit of WD40 on it ( usualy fixes everything ) work it back and forward a few times and then it fees up, well until you drive the car and the WD40 wears off
any ideas ?
Old May 29, 2007 | 06:15 PM
xr4x4rs's Avatar
xr4x4rs
the acutator should be very stiff anyhow
like really hard to pull
if its soft it means the diaphram is worn
Old May 29, 2007 | 06:19 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I think he means the Wastegate arm, not the Actuator!!
If this is the case, then there is a good chance that the pivot pin is warped, probably from excessive heat.
Old May 29, 2007 | 06:21 PM
boost mad's Avatar
boost mad
thats exactly what i mean...
and thats exactly what i was hoping hadnt happened.
can it be fixed without having the turbo rebuilt?
Old May 29, 2007 | 06:24 PM
Christian and Beccy
#1 in Spelling Club
Yes, IMO it can. But you will still have to remove the Turbo and wrestle the Turbine Housing off really. Maybe it can be done with the Turbine housing still attached to the Turbo, will be down to whoever you get to fix it.
Old May 29, 2007 | 06:25 PM
xr4x4rs's Avatar
xr4x4rs
Christian and Beccy
yeah i miss read it lol
boost mad's Avatar
boost mad
Any one want to volentier as i need to sell it lol and dont want to pay for a rebuild as it hasnt done many miles since i brought it
