checking for air leaks
Old May 29, 2007 | 04:36 PM
Steve Escos's Avatar
Steve Escos
Default checking for air leaks
Car is now idling high since fitting my pro alloy cooler. Been told to check for air leaks however just wondered what people had used to pressurise the system. Any help appreciated.
Old May 30, 2007 | 02:44 PM
Dave Henshall's Avatar
Dave Henshall
its much easier to check for air leaks with the engine running and a can or carb cleaner....
squit the carb cleaner around all the joints/gasgets on the inlet side, when the engine suddenly revs up (becasue its sucked in some of the solvent) you will have found your leak. onyl takes a few mins to do aswell as its fairly obvious when u've found it...
Old May 30, 2007 | 03:06 PM
ian sibbert's Avatar
ian sibbert
Or you could use one of these....
Old May 30, 2007 | 03:15 PM
Rippers's Avatar
Rippers
Monte Geek
You don't happen to have those big Mikalor hose clamps do you? They where where all leaking on mine
Ian thats a proper tool
Old May 30, 2007 | 04:51 PM
Steve Escos
No not using mikalor clamps but when i had a look it looks like the gasket has pushed out in places. Tried spraying carb cleaner but couldn't hear any differences
Old May 30, 2007 | 05:21 PM
redrsmk5's Avatar
redrsmk5
can you tell me where the needle is on ur centre pod gauge at idle please???
i posted about air leaks some while back and as yet have not found mine
Old May 30, 2007 | 08:09 PM
PewteRS's Avatar
PewteRS
Mine is hunting at idle since fitting my Radtec cooler and i fitted mikalor clamps but they all seem tight..................what was wronbg with them Paul
Old May 30, 2007 | 08:14 PM
Rolls's Avatar
Rolls
ditto - are they that bad?
Old May 30, 2007 | 08:26 PM
Rippers's Avatar
Rippers
Monte Geek
Both me and Duncos had them removed by Harvey/Ahmed as they there fault is the don't grip completely round. Duncos will hopefully explain more
Old May 31, 2007 | 01:34 AM
Arnie's Avatar
Arnie
If the throttle bracket had been removed recently, it could well be those two bolts which go through the plenum......really stupid design. That where my leaks are (I hope)
Old May 31, 2007 | 07:40 AM
Dave Henshall
i replaces all my scabby old ford clips with some stainless Hi-Grip ones...
you can then use a 7mm flexi drive 6 point socket to tighten them as tight as you can plus teo full turns = no leaks
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Flatlinedan
Sep 18, 2015 12:41 PM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
