quick cossie question
Old Sep 20, 2004 | 10:27 PM
Cossie-Spen's Avatar
Cossie-Spen
Default quick cossie question
are the injectors in a standard ecort cossie the same as 2wd saphie i know the colour is different but is there any problem in fitting theescort ones in me saff thanks marc
Old Sep 20, 2004 | 11:49 PM
bbigman2000's Avatar
bbigman2000
really dont know bud, but bump for you some nice dude will help hopefully
Old Sep 21, 2004 | 06:48 AM
Cosworth4388's Avatar
Cosworth4388
im not sure if the flow is exactly the same but i know the dark blues will fit into the 2wd fuel rail..
I take it were not on about the eco-tech type
Old Sep 21, 2004 | 07:12 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
My 2wd saff came with dark blue 4x4 injectors and was running a stage 1 no problem. HTH you.
Old Sep 21, 2004 | 07:35 AM
wimwerf's Avatar
wimwerf
i think the make is different (brand)
Old Sep 21, 2004 | 09:05 AM
Dave Henshall's Avatar
Dave Henshall
the yellow (fitted to 2wd) and blue (fitted to all 4x4) flow the same fuel and are both capable of runing stage 1, ie 15 psi of boost. the blue ones though IIRC produce a better spray pattern which makes for better combustion.
Old Sep 21, 2004 | 05:45 PM
Cossie-Spen
mmm thanks guys so the ones off the large turbo escos will be fine up to stage one
Old Sep 21, 2004 | 05:46 PM
Ima-Racing500's Avatar
Ima-Racing500
Yep no probs.....both yellow and blues are Weber items.
Old Sep 21, 2004 | 05:48 PM
Cossie-Spen
thanks guys
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Bransby
Sep 11, 2015 01:09 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
