Interior Light
Hi guys my interior light in the front has stopped working on my saphh when you open the doors,if you switch it permanently on it works also the rear light works when open a door any ideas? thanks
As said just the PIN switch most likely, new £3 from ford, just 1 screw to fit, it is best to put coppaslip on the contacts as this tops them from corroding, this is what I did with my four new ones I put in just to be on the safe side.
155lee
Oct 24, 2015 11:11 AM
The Enigma
Sep 12, 2015 10:12 PM
