Been here a while never had a sig :(
could someone if possible do me a sig for my cossie? some pics are here and the spec below, Been on the site and asked before but never got much joy. Many many thanks in advance. obviously the pic you think is best out of these
http://s5.photobucket.com/albums/y19...%20RWD%20Saff/
Standard cosworth engine running on 10w 50 silkolene pro s
Multi layer head gasket
Ford headbolts
909 motorsport ignition leads
MSD chip
14mm plenum spacer
All new top ends gaskets and valve stems
New timing belt
Bailey breather system
Uprated samcos hoses (every hose)
Swirl pot
Pro alloy intercooler
Rewired fuel pump
Ap organic clutch
82 degree thermostat
All new sensors (tps, air temp, water temp)
Ford 071 spark plugs
Gruop a coil
Suspension:
Coilovers
Polybushed through out
Adrenaline rear strut brace and chasis frame connectors
R&b hub shims
Brakes:
Grooved discs all round
Red stuff pads all round
Braided brake lines all round
