help needed brakes?
Old May 26, 2007 | 11:43 PM
leexr3i's Avatar
leexr3i
Default help needed brakes?
hi found a big pudle under my car the other day and its brake fluid.i know bad lol. have just found out that 1 of the pipes that comes out of the brake resevour has split there are two pipes and they lead to the modulators on the left and the right for the abs . and they are plastic , any1 know where i can get a new 1? many thanks lee
Old May 27, 2007 | 06:57 AM
PLASTIC, will not be plastic if brake pipes, be COATED METAL pipes that look like plastic though, just regular metal pipes, make some up.
Old May 27, 2007 | 12:18 PM
daveselwood's Avatar
daveselwood
Default pipes
did the same to my old series 2 got some from a breakers try one of the breakers on here
Old May 27, 2007 | 01:18 PM
SafeChav's Avatar
SafeChav
Hes talking about the return pipes from the modulators, which are plastic!
Just get rid of the ABS mate, its shit anyway you'll be killing two birds with one stone
Old May 27, 2007 | 04:46 PM
leexr3i's Avatar
leexr3i
didnt know i could do that m8, what do i need to do to ? what bout the holes left over in the brake resevour? u got any pics?
Old May 27, 2007 | 05:09 PM
SafeChav's Avatar
SafeChav
Cut a long story short, you fuck the modulators off, get a couple of brake pipes made up to patch up the loose ends where the modulators once connected to, and get a non ABS reservoir which doesnt have the return pipe connections
No pictures im afraid
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
