custom series 1 inlet
for sale here is a custom series 1 rs turbo inlet manifold modified by field motorsport,
this used to belong to the user gus off this board but i bought it as i was thinking of changing my set up but am now sticking with what i have so its back up for sale
custom top plenum chamber with side mounted throttle body (this cleared the brake servo etc on gus's s1 so not sure if it will on a s2 as well so its down to you to find out) but can also swap back to the centre of the plenum by swapping it with the blanking plate as it was originally mounted there then moved to the side if you know what i mean lol
has a efi fuel rail mounted to it for injectors and the head mounting face has no iinjector cut outs so i think it will go on mfi and efi heads but check yourself before buying as im not 100% as ive never used it
complete with throttle body,fuel rail, fuel pressure reg which i think is a cossie 4x4 item?
£250
old pic of it when it was on gus's s1 turbo which made 337bhp on the bench dyno
£250
wowk
Mar 30, 2021 07:49 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
