Lambda prob thread
Old May 24, 2007 | 01:31 PM
Rippers's Avatar
Rippers
Monte Geek
Default Lambda prob thread
M18 x 1.5 ?
Old May 24, 2007 | 01:33 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Yes
Ford lambda sensor(in exhaust housing) is smaller
Old May 24, 2007 | 01:35 PM
Rippers's Avatar
Rippers
Monte Geek
Originally Posted by B9KOS
Yes
You trying to confuse me?
Old May 24, 2007 | 01:37 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yes
I think i have
Old May 24, 2007 | 01:51 PM
Rippers's Avatar
Rippers
Monte Geek
You have so explain it bitch
Need to know urgently!
Old May 24, 2007 | 02:05 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Narrow band or wide band?
The wide band one is as you said, the narrow band one is smaller, I have both bosses in stock .
http://www.randbmotorsport.co.uk/sho...ID=6&offset=10
Old May 24, 2007 | 02:23 PM
series_one_rst's Avatar
series_one_rst
i`ll be needin one of these beauty`s soon, mig welder will do it wont it doesn`t need tig does it.
Old May 24, 2007 | 04:06 PM
Rippers's Avatar
Rippers
Monte Geek
I don't care I just want to fit my Pectel monitor exhaust temp sender
Old May 24, 2007 | 04:14 PM
Mig is fine even with mild wire on stainless or mild to weld in.
Old May 24, 2007 | 04:19 PM
GARETH T's Avatar
GARETH T
very old photo,,, but i guess this is what you want
Old May 24, 2007 | 04:27 PM
Rippers's Avatar
Rippers
Monte Geek
Cheers Gareth I'll take the balnking plug out tonight and find out myself.
Can you bend the sender then? How far does it need to go in and should it touch anything when mounted?
Old May 24, 2007 | 04:28 PM
GARETH T's Avatar
GARETH T
i think mine goes in about 25mm,,,,,, and yes you can bend it
Old May 24, 2007 | 04:41 PM
Ryan's Avatar
Ryan
will the exhaust gas temp sensor get cooked like the lambda ones when running ALS?
dont know myself, just wondered
Old May 24, 2007 | 04:46 PM
GARETH T's Avatar
GARETH T
well they are ok till 1200 degrees
Old May 24, 2007 | 05:28 PM
series_one_rst
cheers mucca.
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
