Cost of standard cams? Or head without cams?
I've maybe found a LT esc cossie head thats in great nick. Everything present bar the cams.
No what would the cams be worth?
I can obviously use my old cams so not a problem if the head is good!
Anything to watch for when using my cams in that head? Or are they identical?
cheers
chop
cheers
chop
cams are different and the head is also different
do you have a spec r turbo dampner as the 4x4 heads dont have one fitted but a 2wd head has one
and then theres the oil feed,,, but just block that off in the head or use it for oil presure gauge readings if you got one
how that helps a little
Danielbetty
Oct 3, 2015 06:01 PM
