Sierra boot locks - cable pull
Old May 23, 2007 | 03:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Sierra boot locks - cable pull
Does anyone know if a saph boot pull will work on a 3dr?
i had the boot lock smoother over and was gonna fit a electronic pop like the mk3 fezzers use, but now i cant be arsed.
so, how hard will it be to fit the lever and cable, or shall i just fuck that all off and use a pair of locking areo catches on the tailgate?
the latter gets my vote lol
Old May 23, 2007 | 03:52 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Depends if theres room to fit the 90 spec lock/latch in the 3 door tailgate.
DOn't know about 90 spec saffs, but when I tried sticking the lock from a 90 spec Sierra hatch into my 88 Saff, it wouldn't fit because the 90 spec locks are completely different in size and shape, so you may be better off looking at a hatch for the source of the new lock.
Old May 23, 2007 | 03:56 PM
Fil's Avatar
Fil
ELASTIC BAND
the xr4is had a electronic pop, would be an easy job , i'd have thought the rs cos 3dr would have too?
Old May 23, 2007 | 04:40 PM
Hatch release will fit, and as said SOME xr4i had electric release.
Old May 23, 2007 | 05:38 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the cables are easy enough, you just need to replace the mechanism
i've got the cable and the fuel flap but not the boot release, but all you need is a 90 spec onwards sierra hatch to rob it from down the scrappy
Old May 23, 2007 | 05:51 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Dan@FastFord
Seens as it's more hassle than its worth for me to convert my Saff, I have a 90 spec hatch ready to go off to the great ironmonger in the sky, with the lever, cable, latch and lock, etc.
If you want it...
Old May 23, 2007 | 07:03 PM
CozzyBrom's Avatar
CozzyBrom
LATER lock will fitt but you need to get cone cutter out and a file to make hole bigger and the locating lugs
Old May 24, 2007 | 09:34 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cozmeister
top man, how much you want for it?
BROM@ZOO
im not using the lock mate, the hole has been smoothed over, so just need the latch bit inside
Old May 25, 2007 | 09:08 AM
Iain Mac's Avatar
Iain Mac
All of the Mk1 XR4is had the electronic boot release as standard. But, when the solenoids started to go, lots of them got standard locks fitted by cheapskate owners or even just had the switch removed.
The Mk2 badge-engineered 2.0 5 door XR4i was just an ordinary Sierra with the standard mechanism.
Old May 25, 2007 | 10:40 AM
zippyobrien's Avatar
zippyobrien
go down maplins, they sell a universal liner actuator for £14,
ive done three boots with these now, and you can set the arm to push or pull.
very easy and takes about 2 hours including the wireing,
do it proper dude
Old May 25, 2007 | 10:41 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
with aero catches you mean?
Old May 25, 2007 | 10:45 AM
zippyobrien
is that what the latches are called that go on the out side of the body work
Old May 25, 2007 | 10:46 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
yeah. black abs plastic catches, a bit like bonnet pins but look 100% better
Old May 25, 2007 | 11:12 AM
zippyobrien
i reckon theyed look the bollocks on your car,
there was a lovely soarer in the jap mag this month with allow snapp catches on the boot, and bumper, they looked awsome to
i take it they delete the locking mechanism alto gether though which is no good onthe road
Old May 25, 2007 | 11:21 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
checkit
http://www.aerocatch.com/
Old May 25, 2007 | 11:27 AM
zippyobrien
there fucking sex,
deffo going on the next project, i take it there pricey?
Old May 25, 2007 | 11:30 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think they are about £35 a pair, i cant remember
Old May 25, 2007 | 12:42 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Originally Posted by Dan@FastFord
cozmeister
BROM@ZOO
Call it £20 and a mention in the mag
Kam B
Sep 24, 2015 10:40 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
