escort mk4 1.4 auto auto - manual?????
Old May 22, 2007 | 01:29 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default escort mk4 1.4 auto auto - manual?????
changing a 1.4 auto to manual on a mk4 escort 1.4l....is it just a case of gearbox and selector change?? cheers ppl
Old May 22, 2007 | 10:12 PM
Series 1 van's Avatar
Series 1 van
its a bugga on youll have to put a extra pedal on your existin pedal box think you change pin i can find out mora have a mk3 auto in yard and have to bridge wire to autobox coz wont start otherwise coz only start in p or n good place for a kill switch also need flywheel, pressure plate, clutch plate,think crossmember the same ?canny hard and a twat if your hot headed hope that helps you
Old May 23, 2007 | 07:29 AM
cossie04's Avatar
cossie04
Not sure if it the case for FWD`s, but you might need a spigot bearing aswell....
Old May 23, 2007 | 08:19 PM
Series 1 van
mk4s havnt spiggot bearin mate and pins the rite 1 av looked the day you need spacers for the pin in pedals and change brake pedal as its too big av looked at my spares one the day
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
