How do you remove a viscous fan?
Old May 20, 2007 | 06:58 PM
cossie04's Avatar
cossie04
Default How do you remove a viscous fan?
As above really...
Its on my 24v cossie lump...
Ta
Old May 20, 2007 | 07:03 PM
On the reverse of the fan there is a large nut, put spanner on and whack, I think it is about 24/26mm from memory, I assume you mean the viscous unit, as the fan itself is held on by a series of bolts clearly visible.
Old May 20, 2007 | 07:06 PM
cossie04's Avatar
cossie04
yeah, viscous unit. Cheers m8...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
