S2 holds back ???
Old May 19, 2007 | 05:19 PM
denbo's Avatar
denbo
Default S2 holds back ???
What do you think is wrong with my RST S2
Q It has plenty of power but does not accelerate smoothly, it judders no matter what gear I am in. Any ideas where to start looking to cure this?
Old May 20, 2007 | 07:53 AM
denbo's Avatar
denbo
Well then i have been told to have look at the fuel sensor if so could someone tell me where it is
Old May 20, 2007 | 02:19 PM
Forget the fuel sensor, look at basics like leads/plugs, and ignition side of things first.
Old May 20, 2007 | 05:51 PM
Have u got it sorted then denbo n if so what was it. I take it u got my text message about checkin spark plugs.
Old May 20, 2007 | 06:39 PM
denbo's Avatar
denbo
Yes i got ya txt matey me got new fuel filter and new spark plugs will fit them 2moro
Old May 20, 2007 | 08:11 PM
Sweet just hope its something simple like plugs or filter.
Old May 21, 2007 | 08:26 AM
antony215's Avatar
antony215
Escort Rs Turbo
Check your plug gaps that maybe the problem
Old May 21, 2007 | 06:51 PM
denbo's Avatar
denbo
New spark plugs in fells much better but for me it still a little bit there new leads ?
Old May 21, 2007 | 08:08 PM
Take ur dizzy cap off n have a look inside the cap n check ur rotor arm. Use a bit of sand paper or a small screw driver n scrape the 4 bits in the cap.(thats if they are a bit corroded)
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
imnoteasy
Aug 30, 2015 09:34 PM
YODI
Aug 30, 2015 01:12 PM
Marcus L
Aug 29, 2015 02:18 PM
Franko99
Aug 29, 2015 01:38 PM
