XR4x4 front brake upgrade?
Old May 17, 2007 | 01:25 PM
xr4x4 mk1's Avatar
xr4x4 mk1
Default XR4x4 front brake upgrade?
Just a quickie
if i was to upgrade my front brakes to standard 4x4 saph cossie size i could use my calipers but with the caliper brackets and disks (of course ) off a saph cossie? or do i need the saph calipers and hubs too ? anyone ?
Old May 20, 2007 | 02:52 PM
Series 1 van's Avatar
Series 1 van
best to use disc and caliper coz the size ov the caliper on 4x4 will be smaller and cossy discs bigeer wont brake on all discs just part ov it
Old May 22, 2007 | 09:42 AM
dojj's Avatar
dojj
Resident Wrestling Legend
you'll need the saph hubs as well as the calipers and the discs as they are of a different offset to the xr ones
you'll also need to return to using cossie wheels, again, due to the offset of teh brakes
Old May 22, 2007 | 06:45 PM
JohnnyB's Avatar
JohnnyB
or use 2wd cossie disks and 4x4 cossie calipers
the disks will fit fine, but the clearance is tight so if you giving it some the disks expand and touch the caliper a bit.
a Little angle grinder work will sort it
original
Apr 28, 2026 05:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
C2 MAK
Aug 20, 2015 09:46 PM
Aug 10, 2015 12:08 PM
