Spray pattern KE injectors
Old May 17, 2007 | 09:36 AM
Willem's Avatar
Willem
Default Spray pattern KE injectors
Who has pictures of a worn KE injector, and a new one, and, for the people who have too much pictures, in between
Old May 17, 2007 | 10:57 AM
SafeChav's Avatar
SafeChav
The spray pattern of them isn't very good actually, i've not got any pictures on the PC but they don't atomise the fuel very well.
Ive got photocopies of an original bosch book on KE Jetronic, they actually made "air shrouded injectors" which gave a lot better spray pattern over the non shrouded ones but i have no idea what cars these injectors were fitted to.
Old May 17, 2007 | 06:13 PM
JesseT's Avatar
JesseT
Old May 18, 2007 | 09:23 AM
Willem's Avatar
Willem
Thanks lads, mine is a little between the correct one and the straight forward one, it sprays quite far, not immediatly a cone shape, also they drip when I push the sensor plate very little, but maybe that's just because I'm teasing the system.
But, I think they are wrong based on what you say and the picture.
About the air shrouded injectors... Who knows which numbers they have, and what cars used them and who uses them in their RST??
Old May 18, 2007 | 10:17 AM
SafeChav's Avatar
SafeChav
I'm not sure if anyone has used air shrouded ones in an RST, just thought i would mention it like, probably a bit pointless in hind sight
Old May 18, 2007 | 11:19 AM
Willem's Avatar
Willem
Well, if there is a possibility it could make a difference, it's allways worth a try, altough there must be someone who allready tried....
Old May 18, 2007 | 11:37 AM
Willem's Avatar
Willem
Did a quick search, came up with this:
I take you need a head modification to feed the air, and to seal the botom...
Old May 18, 2007 | 12:11 PM
SafeChav's Avatar
SafeChav
It would appear so from that yes, propably why its not been done before
Old May 18, 2007 | 10:12 PM
Willem's Avatar
Willem
This is how audi uses them, so maybe an idea.....
Old May 18, 2007 | 10:14 PM
SafeChav's Avatar
SafeChav
Maybe!
Willem's Avatar
Willem
Old May 19, 2007 | 09:41 PM
Rick's Avatar
Rick
the spray pattern/general fuel delivery is very very good on these injectors as std.
Old May 19, 2007 | 09:54 PM
Willem's Avatar
Willem
You know any more about these injectors? Any experience?
mk3ste
Oct 17, 2021 10:09 AM
155lee
Sep 6, 2016 11:10 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
