my current project (black s2) bumper now fitted
Modified front bumper with middle section cut out and bumper strips all smoothed out witch requires loads and loads of sanding to be done the lightly sand with very fine sand paper to get a smooth finish
Then filled the bumper strips with filler and sand down to get a smooth as possible finish and also sanded down the bottom lip so a smooth finish
Bumper fitted with vr6 splitter lots of cutting involved now finished ready to prime and paint
While waiting for bumper to be sprayed I started on the alloys first I primed the alloys
Primed alloys front and back with 5 coats of primer
Then I sprayed started spraying the alloys black 1 coat at a time total 11 coats of smooth black paint and 5 coats of lacquer to make them shine nice.
I then started on the centre caps
I sanded down the caps to bare metal and then applied 3 coats of primer and 11 coats of paint and 5 coats of lacquer then put the rs badges on them to make them look better
Then I stated buying some things for the car
rs turbo bad boi bonnet with chrome rain catchers
Bumper primed needs few bit sanding down to get a smooth finish
and how the car looks at the moment
let me know what you think
cheers dan
cheers dan
sexy mate real sexy
put in you title some thing like (black s2) at the end as makes it easyer for people to spot what it is
good luck with the build mate wheels look good
rog
Sep 4, 2015 12:10 PM
muz
Aug 16, 2015 12:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
