ABS Set up without ABS!
Old May 14, 2007 | 06:39 PM
mikevryan's Avatar
mikevryan
Default ABS Set up without ABS!
Hi all
Just finishing a rally car a (4x4) with the abs set up les the distribution block. All I want to do is get some power assistance. Can this be done just wiring the large brown and red wire to pos/neg on the motor?
All help much appreciated.
Old May 14, 2007 | 08:27 PM
foreigneRS's Avatar
foreigneRS
Testing the future
OBVIOUSLY YOU WOULD NEED THE PRESSURE SWITCH WIRING IN AS WELL, AND THAT WOULD HAVE TO CONTROL THE MOTOR VIA A RELAY (sorry for caps lock)
also, i believe that the boost system only works on front brakes, not rears, so don't know how not having the block and valves may affect distribution and bias - be careful
steve.rst
Mar 15, 2016 08:01 AM
lime
Sep 25, 2015 06:56 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
cossiestu
Sep 19, 2015 05:19 AM
