poor idle on zetec
Old May 14, 2007 | 01:27 PM
jdfiesta's Avatar
jdfiesta
Default poor idle on zetec
I've got a 2.0 converted Si.
It seems to have developed a really rough idle. it was never perfect, but recently it seems to have got worse.
Today i've had ISCV off and given it a clean. tried different ECU, different MAF. put different TPS on it.
anyone got any other ideas?
Old May 14, 2007 | 02:26 PM
cozmeister's Avatar
cozmeister
More boost Igor!
leads and plugs ok?
ISCVs need to be cleaned when they've been taken apart (well, the two halves separated anyway). Otherwise they just stay stuck when they're being cleaned, all you end up with is a shiny air tunnel
Old May 14, 2007 | 11:16 PM
SafeChav's Avatar
SafeChav
What sort of rough idle?
Surging?
Old May 15, 2007 | 09:49 AM
jdfiesta's Avatar
jdfiesta
sometimes it will idle fine, then it just starts chugging all of a sudden.
occasional miss when cold too.
runs fine other than this though.
thinking maybe cracnk breather hose, or, lambda, but not sure if lambda is used at idle
Old May 15, 2007 | 10:46 AM
SafeChav's Avatar
SafeChav
could have developed an air leak somwhere possibly aswell.
Old May 15, 2007 | 01:08 PM
jdfiesta's Avatar
jdfiesta
if the weather ever clears i'll have a proper gander at it.
getting a touch annoying, it's worse when cold
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
mondeomark
Sep 28, 2015 06:28 AM
