4x4 and 2wd abs pumps
Will a 2wd abs pump fit on and run correctly on a 4x4 as today i noticed that a 2wd pump sits alot tighter to the inner wing moving it away from my manifold and turbo.......i know the pipes will need swopping as well but will it fit cheers andy
i "think" they have the resivours on different sides
if it's not the same orientation then i'd not fit it
from what i can figure out, there were atr least 4 different variations of pump used across the range
big_Rad
Sep 15, 2017 09:36 AM
FlashRS
13
Aug 31, 2015 06:02 PM
