Which hydraulic clutch is best on a T5...
Old May 13, 2007 | 05:14 PM
Mr C's Avatar
Mr C
Default Which hydraulic clutch is best on a T5...
Reyland do one that acts on the O/E arm and bearing and Burton Power also do one that sits where the O/E bearing did and replaces the arm and bearing. Which type is better in your opinions and which is better value for money?
Any other types and manufacturers available?
Old May 13, 2007 | 05:25 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I only have experience of the Reyland one, and it is one of the best mods I had done to the car . Clutch life is doubled and feel is vastly improved .
Old May 13, 2007 | 05:30 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: Which hydraulic clutch is best on a T5...
When comparing prices you should be aware that mine includes the pedal end too.
Old May 13, 2007 | 05:35 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
How much for a complete 4x4 hydrualic kit please martin? - fitted and DIY
Old May 13, 2007 | 05:45 PM
Mike Rainbird
Caraholic
Price is on HIS website
Old May 13, 2007 | 05:51 PM
Martin-Hadland
Ł300 supply only or Ł575 fitted, all plus vat. Nice if its done at the time of replacing the clutch as fitting the clutch would be FOC...
Old May 13, 2007 | 05:55 PM
Ginge !'s Avatar
Ginge !
just finding my feet
martins is a better idea cause you dont need to take the box off to remove the slave cylinder
btw the conversion aint hard to do if your a little handy with spanners and get a push slave cylinder
the pedal end aint that hard either and the fiesta resivours aint that expensive too
but for 300 quid,,,, is it worth the fucking about
Old May 13, 2007 | 05:58 PM
Mr C's Avatar
Mr C
well thats a no brainer then Martin, just seen your product, flywheel is tempting too, do you do a heavy duty clutch cover for my 6paddle AP?
Is the arm available exchange, you have them on the shelf or you need mine to mod first?
Old May 13, 2007 | 05:59 PM
RWD_cossie_wil
My engine and box are out the car at the moment anyway - worth doing for an AP 6 paddle and uprated pressure plate?
Mike, fook off - Easier to get it from the horses mouth so to speak
Old May 13, 2007 | 06:00 PM
RichardPON's Avatar
RichardPON
Mark - I've driven Mike's car with Martin's conversion and it's fantastic. Transforms the drive of the car.
Old May 13, 2007 | 06:03 PM
GARETH T's Avatar
GARETH T
i like martins more,, if the slave leaks,or its pipes its outside the box,,
Old May 13, 2007 | 06:08 PM
Mr C's Avatar
Mr C
Superb Richard cheers, do you remember if that pressure cover is std or uprated on the 6paddle, I wont get under the car now untill my box is ready to fit tut
Old May 13, 2007 | 06:10 PM
Martin-Hadland
On 2wd belhousing and arm are exchange items which can be sent out before old units are returned, a charge is made for this but is fully refundable on their return.
Old May 13, 2007 | 06:22 PM
Mr C's Avatar
Mr C
thankyou Martin, your flywheels have any adverse effects? PMs welcome, there was chat about loss of torque, poor driving etc but my car is track mostly, I cant see any downsides. Thanks again.
Old May 13, 2007 | 06:36 PM
Martin-Hadland
A std 2wd weight flywheel will be fine.
Old May 13, 2007 | 06:51 PM
RichardPON's Avatar
RichardPON
Mark - the clutch on my old engine is an Alcon 6 paddle with a std Ford cover.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
