Are 2wd and 4x4 cossie rads the same ?
no,they have a pipe on them and its in a different place.when i fitted a 4wd engine to my 2wd car i had to design a new coolant system to mate all the bits up!its physically the same dimensions etc and will fit tho.
i used my mates 2wd rad when mine blew up
alls i had to do was drill 2 holes in the cover so my metal pipe fites to the rad
the rad will bolt up and everything mate, dont know about if your using std intercooler though
4wd doesnt have an extra pipe mate
it looks like it does buts its blanked off
the only difference is the metal pipe that attaches to the rad 2wd is just straight down and 4wd is L shaped
look at alloy rads they are listed for all cosworths not different models
Perhaps theres a difference once the cars came with air-con fitted
FlashRS
13
Aug 31, 2015 06:02 PM
