Clutch
Old May 13, 2007 | 10:47 AM
monkey24's Avatar
monkey24
Default Clutch
how do you know if your concentric slave cylinder release bearing is knackered?
Ford mondeo 1999 2.0lx
Old May 13, 2007 | 10:51 AM
SafeChav's Avatar
SafeChav
clutch won't disengage....
grinding/squeaking noises when the pedal is depressed
hard to get into gears, very bad crunching in reverse
creeping forward with the car in gear and clutch depressed
Old May 13, 2007 | 12:44 PM
mechanic28's Avatar
mechanic28
what symptons have u got?
Old May 13, 2007 | 05:23 PM
monkey24's Avatar
monkey24
sounds like marbles ratting around a bowl when you put the clutch pedal down.....the garage that swapped my clutch said he also changed the bearing......got a feeling its either faulty or he charged me for it and didnt do it.
had it back 3 times now and he says its the tappets but i think he just doesnt want to split the engine and gearbox again
Old May 15, 2007 | 11:46 PM
monkey24's Avatar
monkey24
anyone?
Old May 16, 2007 | 12:03 AM
SafeChav's Avatar
SafeChav
how can it ever be engine tappets if the noise disappears when you push the clutch in?!
Old May 16, 2007 | 06:18 AM
monkey24's Avatar
monkey24
otherway round mate.....hear the noise when clutch pedal is to the floor and there some revs on ie changing gear. stops again when you take your foot off the clutch
Old May 16, 2007 | 09:33 AM
SafeChav's Avatar
SafeChav
ahhh yea sorry that was my mistake, but even so an engine noise shouldnt be influenced by the clutch pedal?!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
