Escort Cosworth brakes fitment to a S2 RsTurbo
Old May 12, 2007 | 05:11 PM
wendall's Avatar
wendall
Default Escort Cosworth brakes fitment to a S2 RsTurbo
Can anyone please tell me what spacer/bracket is required to fit Escort Cosworth front brakes to a Series 2 RsTurbo?
Old May 12, 2007 | 08:15 PM
SafeChav's Avatar
SafeChav
Speak to Tony (Nuts R Us) on here, i'm sure he can sort you out with the correct brackets
Old May 28, 2007 | 03:09 PM
wendall's Avatar
wendall
Default brakes
couldnt locate that member got any numbers for me to ring? or email address's?
thanks
Old May 28, 2007 | 04:56 PM
Alvyn's Avatar
Alvyn
Default Re: Escort Cosworth brakes fitment to a S2 RsTurbo
the calipers are near enough a straight replacment or you MAY need to use a 1mm washer on both the bolts to centralise to hub and you need to use 2 w/d Cos discs job done!
Old Jun 25, 2007 | 07:33 PM
pingu's Avatar
pingu
depends if there 2wd or 4wd calipers the 4 wd one are a right pain to fit
Old Jun 26, 2007 | 09:41 PM
NUTS RuS's Avatar
NUTS RuS
Read the sticky in the top of the Escort section for help
Old Jun 26, 2007 | 11:39 PM
SafeChav's Avatar
SafeChav
You mean the 2wd drive ones.......4wd ones are piss easy to fit.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
