Injector flow rates
Old May 12, 2007 | 01:19 PM
simonc's Avatar
simonc
Default Injector flow rates
Just bought a Cossie thats running 8 standard dark blue 4x4 injectors with a proper RS500 inlet, will 8 standard injectors flow more than 4 greys ?
Boost seems a bit low for 8 injectors,peak 1.5 bar drops back to 1.3 bar at high rpm,would of thought i could run around 1.8 bar or so with 8 injectors,i am going to have it setup properly but was curious on the difference in flow.
Cheers Simon.
Old May 12, 2007 | 01:23 PM
- Sim -'s Avatar
- Sim -
standard comp ratio?
1,8 peak is then the boarder i think.... if you want to have the engine for longer time...
1.5 all the time would be okay for standard comp I think.
dunno what the dark blues flow.... sorry
Old May 12, 2007 | 01:28 PM
simonc's Avatar
simonc
Comp 7.5:1 & its fitted with water injection.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
