rs2000 improvements..
ive got a fse power boost valve but dont know if its worth fitting it and exactly how... im not completely injection minded...lol do i need to remove the standard fuel regulator
Dont expect big things from them,(Power Boost valve) seems a joke they can sell it with that name. just an ajustable fuel pressure regulator.
If you are going to fit one get it set up by someone who knows what they are doing on a rolling road.
needs setting up first
better to get other mods like exhaust and cams and a bit of head work done before you do the valve business
don't forget to change the chain if it's got a few miles on it either
you sure?
jim's running a 2.3 in his and he's using 210 injectors (don't ask me, i don't have a clue) from a vauxhall and it's knocking out 170 brake using the 8V head as per his rr print out at geoff bloor a few weeks ago
and thats with a knocking bottom end (but i will let him mention that to you as it's a bit embaressing
what does the fpr look lke on teh 16V then? on the 8v lump you can pop the cap off and use an allen key to twiddle it a little one way or the other to give you more/less
yes it's basic backyard technology but theres no pint in forking otu loads of dosh for soemthing jsut because it's got a fancy knob on it
Pwrs2k
120
Oct 16, 2015 03:16 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
